In ConnectCAD, specialized devices represent sockets or pairs of sockets on connector panels. An actual physical panel is a piece of sheet metal that has a number of connectors on it. In a schematic drawing, connectors from the same panel may be placed at various locations all over the drawing. Each physical panel has several schematic devices, one for each socket (terminal panel/term panel) or socket pair (jackfield/jack).
● A term panel (terminal panel or demarc panel) is an array of connectors of the same type, typically mounted on a panel on the back of an equipment rack. These connector arrays join wiring within equipment racks to longer cables running in ducts or under floors to various other parts of a building. During installation, the rack wiring can take place off-site in a clean area if needed. During the lifetime of the system, the mounting location on a rack allows cabling between rooms to be easily re-purposed as technology changes.
● A jack (or jackfield) is an array of connector pairs of the same type on a panel. Jackfields are normally mounted in up/down pairs on the front of equipment racks. Outputs from equipment are conventionally connected to the top row and inputs are on the bottom row. Jackfields allow a system’s signal processing chain to be monitored, tested, or adapted to temporary needs; jackfields are, in fact, a primitive form of signal routing. Any output can be connected to an input by plugging a short cable (patch cord) into the corresponding ports. Normalized or linked jack pairs provide a connection between up and down ports when no patch cord is present, while allowing a user to override this connection by inserting a patch cord. This provides a convenient interface for engineers working on a system to access signals without having to disturb the rack wiring.
● A DIN rail is a standardized type of terminal block array used for low-voltage electrics.
● A connector panel represents custom-made panels with connectors of different types; these are typically found in theaters and similar venues. Permanent wiring is terminated on custom panels at facilities boxes throughout the building to provide cables routes for productions to use. The Conn Panel Input and Conn Panel Output tools are special panel connector devices that can be associated with a Conn panel on the Rack Elevation layer. See Creating connector panel layouts.
Specific device name prefixes indicate the device’s panel type. The Check Drawing command recognizes the panel prefixes, and excludes panel devices from the duplicate device name check. This prevents unnecessary duplicate device warnings for panels.
Device type |
Device Name Prefix |
Terminal panel |
VTP_, ATP_, DTP_, OTP_ (the first letter indicates Video, Audio, Data, or Optical) |
Jackfield |
VJF_, AJF_, DJF_, OJF_ (the first letter indicates Video, Audio, Data, or Optical) |
DIN rail |
DIN_ |
Connector panel |
CTP_ |
Specialized devices can be placed on the drawing, or placed “in line” on a circuit, dividing the circuit where they are placed. Terminal panels have a special socket that can accept connections from either side.
If an existing jack (jackfield) or terminal panel device is already selected when placing a new device, the new device is sequentially numbered.
To place a specialized device:
1. Click the tool that matches the type of required device from the Schematics tool set.
2. For jack (jackfield) and panel tools, click the Preferences button on the Tool bar to open the Preferences dialog box. By default, the values from the ConnectCAD settings are applied (see Specifying ConnectCAD settings), but they can be overridden here.
3. If placing the device over an existing circuit, the circuit is highlighted to indicate that the device will be inserted into the circuit. Click to place the device.
Depending on the tool type, one of the following dialog boxes opens automatically: VDA tool, ADA tool, Jackfield Setup, Term Panel Setup, or Connector Panel Setup. Specify the device parameters.
4. Specify the device parameters and labeling options, and click OK to place the device into the circuit or in the drawing.
If you continue placing the same jackfield or terminal panel device, the device number automatically increments.
