Mapping layer and class names
Prior to import and export operations, map the DXF/DWG or DWF layers to Vectorworks classes or layers as desired. Use AIA standard layer names, or create a custom set of names. Save custom mapping sets for specific clients for easier file import and export.
When multiple classes are exported into a single layer through mapping, the objects maintain their original attributes by having their attributes set to object instead of set to class.
Managing mapping sets and standards
To manage mapping sets and standards:
1.      Access the mapping dialog box during either import or export operations, as follows:
        From the DXF/DWG Import Options (or DWF Import Options) dialog box, click Advanced. From the Advanced DXF/DWG Import Options (or Advanced DWF Import Options) dialog box, open the Classes/Layers pane, and click Manage under the Classes/Layers heading.
        From the DXF/DWG Export Options (or DWF Export Options) dialog box, click Manage under the Class/Layer Mapping heading.
The Import (or Export) Layer Mapping dialog box opens. The import and export settings are slightly different.
2.      From the Mapping sets tab, map the DXF/DWG or DWF layers to Vectorworks classes or layers. Select the Mapping Set to edit. The list of mapping pairs displays all items to be mapped from the file. To map an item, select it and then do one of the following:
        To use a standard name, select a Standard, and then select a standard name from the pull-down list of class/layer names below the pairs list.
        To enter a custom name, click in the second column of the pairs list and enter the desired name. Alternatively, click Edit, and enter a custom class/layer name in the Edit Mapping dialog box.
When finished mapping, click Save and name the mapping set.
3.      Click the Standards tab to create or edit standards files. Select a standards list and add, edit, or remove names as needed. When finished editing, click Save and name the set of standards.
4.      Click the Manage tab to manage saved mapping sets or standards. Select which type of files to manage; the files you have edited are listed. Select a name from the list, and then click the appropriate button.
        Rename: Enter a new name for the file. If the entered name is already assigned to another file in the same folder, you’re prompted to confirm that you want to replace the existing file.
        Delete: When prompted, confirm that you want to delete the selected file.
Files in a workgroup folder or in the application folder cannot be renamed or deleted.
Creating mapping sets and standards files manually
You can create text (.txt) files to use for mapping sets and standards using any text editor.
        For a standards file, simply place each standard name on a separate line.
        For a mapping set file, the first line is a header row that doesn’t contain any mapping pairs, but it must include a tab. For example, you might put a description, followed by a tab, followed by the date on this line. Directly below that, place each mapping pair on a separate line. The first member of each pair is the Vectorworks class or layer name, followed by a tab, followed by the DXF/DWG or DWF layer name.
DXF/DWG and DWF export options
Sharing custom content using workgroup folders
