DesignSeries00007.pngData mapping expressions
Each formula consists of one or more expressions from the following list. The expressions are described in more detail in the rest of this section.
Expression
Description
Constants
Types of data, such as integers, Boolean constants, numbers, and text constants
Fixed values
Text strings, numerical and logical values, and so on
Operators
Addition, subtraction, comparison, and so on
Variables
Vectorworks data sources, such as object parameters, style information, class name
Functions
Mathematical functions, string manipulations, conditional functions, and more
ELSE
Method of adding alternative data mapping, if the previous one yields an empty value
Constants
Constant
Description
Examples
Boolean
Values are used for Boolean parameters, and are either true or false, written as string constants enclosed within apostrophes
‘FALSE’
‘TRUE’
Integer
Positive or negative numbers and 0, written as numbers with no decimal point or apostrophes
4
125
Rational number
Real number values, written as a number with a decimal point and no apostrophes
3.14
-12.0
248.141539
Text
String values enclosed within apostrophes
‘Unstyled Wall’
‘INTERNAL’
‘NOTDEFINED’
Operators
Operator
Description
Unary Plus
Unary Minus
Binary Plus, Addition, Concatenation
Binary Minus, Subtraction
Multiplication
Division
Logical EQUALS
Logical NOT
Logical OR
Logical AND
Logical NOT EQUAL
Greater than
Less than
Greater than or equal
Less than or equal
Variables
Variables represent sources of data from Vectorworks. They can be combined with constants, function results, and other variables by using operators. The variable type (name) is the same as that of the data source type. Variables are enclosed by square brackets, since spaces are permitted in the name.
Variable
Format
Example
Parameters from an object
[Object.NameOfTheParameter]
If the parameter is a pop-up field, the variable returns the localized value. If you need the universal value instead, add an asterisk after the name of the field.
[Object.Config]
[Object.Column ID]
[Object.Struct Type]
[Object.structuralUse*]
Vectorworks name
[Object.VW_Name]
[Object.VW_Name]
Record field data from a record format
[Record.NameOfTheRecord.NameOfTheField]
If a record by that name is not attached to the object, then the default value of the record field is taken as the value of the variable.
[Record.MyRecord.Price]
[Record.Plant Record.Latin Name]
Data from style
[Style.NameOfTheField]
Currently supported data fields are: Name (the name of the style), Mark, Function, Description, Exterior (Boolean), Load-Bearing (Boolean), Fire Rating, Combustible Construction (Boolean), Compartmentation (Boolean), U-Value, Acoustic Rating, Cost Index System, Cost Index Code, Model, Manufacturer.
[Style.Function]
[Style.Name]
[Style.Fire Rating]
Component
[Component.NameOfTheField]
Currently supported data fields are: Name (the name of the component), Function, Class, Thickness, Lambda, U-Value. When the “export by components” option is not used, these variables correspond to the core component.
[Component.Function]
[Component.Thickness]
Class name
[ClassName]
[ClassName]
Layer name
[LayerName]
[LayerName]
Story name
[StoryName]
[StoryName]
Functions
Function
Description
PI ( )
SIN (radians)
Returns the sine
COS (radians)
Returns the cosine
ABS (number)
Returns the absolute value
SQRT (number)
Returns the square root
INT (number)
Returns the converted integer value
REAL (number)
Returns the converted real value
IF (logical_expression, value_expression1, value_expression2)
Calculates logical_expression and returns the calculated value of value_expression1, if TRUE, or value of the value_expression2, otherwise
SELECT1 (number_expression, value_expression1, value_expression2, …, value_expressionN)
Calculates number_expression and returns the calculated value of value_expression1, if the result is 0, value of the value_expression2, if the result is 1 and so on. Returns the value of the last expression, if the result is bigger than N-1. The number of the function parameters must be 3 or more.
SELECT2 (logical_expression1, value_expression1, logical_expression2, value_expression2, …, logical_expressionN, value_expressionN)
Calculates the first logical expression and returns the calculated value of value_expression1, if the result is TRUE; otherwise, continues with the next logical expression and value expression pair. The number of the function parameters must be even, and greater than 2.
COUNTER (“name”)
Returns auto-incremented values (for generating unique values)
BOUNDS (“name”)
Returns X-, Y-, Z-, or Width/Height/Depth dimensions of an object
LEFT (text, count)
Returns the left side of the string, using the specified count of characters. Returns an empty string if the count value is incorrect.
RIGHT (text, count)
Returns the right side of the string, using the specified count of characters. Returns an empty string if the count value is incorrect.
MID (text, index, count)
Returns the right side of the string, split by the position index (0 is the position of the first character) and using the specified count of characters. Returns an empty string if the index or count values are incorrect.
FIND (subtext, text)
Returns the zero-based position of subtext in text, if found, or -1 if not found.
Example: example FIND (‘fo’, ‘foo’) returns 0 and FIND (‘oo’, ‘foo’) returns 1.
LEN (string)
Returns the length of the string
INSERT (string1, index, string2)
Inserts string2 in string1 at the given position index
DELETE (string, index, count)
Removes the right side of the string, split by position index and having the specified count of characters
REPLACE (string1, string2, string3)
In string1, replaces all occurrences of string2 with string3
TRIMLEFT (string)
Returns the left trimmed string from whitespaces
TRIMRIGHT (string)
Returns the right trimmed string from whitespaces
MAKEUPPER (string)
Returns the uppercase string
MAKELOWER (string)
Returns the lowercase string
GETCOMPONENTINFO (index, selector)
Returns information about the selected component (wall/slab), where index is the number of the component, and selector is one of the following:
1 (component name)
2 (component function)
3 (component class)
4 (component thickness)
Data mapping examples
Creating or editing mapping formulas
Using the Data Manager
