DesignSeries00062.pngCreating slab drainage systems
The Slab Drainage tool is in the Building Shell tool set.
Use the Slab Drainage tool to design drainage systems for slabs that are regularly exposed to water, such as industrial floors, concrete pavements, and flat roofs. Creating drains and valleys affects slab geometry; the process creates slopes and ridges, and potentially changes the curb height. Most of these calculations are computed automatically, but user settings and the placement of drainage elements sometimes result in errors when the geometry created is impossible.
Mode
Description
Edit
Edits selected drains, drain valleys, slope valleys, and slope markers; for multiple selection, all selected objects must be of the same type
Create Drain
Places a new drain with related slope valleys
Connect Drains
Connects two existing drains with a drain valley and automatically deletes inappropriately oriented slope valleys
Create Valley
Adds a slope valley to an existing drain
Settings
Opens the Slab Drainage Settings dialog box; set defaults for drainage elements to be added to the selected slab
Adding drains to a slab
Connecting drains on a slab
Creating valleys on a slab
Slab drainage settings
Editing slab drainage elements
Correcting slab drainage errors
