Designing buildings
Creating floorsCommand |
Workspace: Path |
Floor |
● Architect: AEC ● Landmark: Landmark > Architectural ● Spotlight: Spotlight > Architectural |
The Floor command can be used to create not only floors, but also decks, patios, stages, platforms, and lofts. The command converts any 2D drawing object into a hybrid (2D/3D) object of any shape and thickness. The source object must be flat and must also be parallel to the active layer plane.
To create a floor:
1. Select the 2D object to turn into a floor.
2. Select the command.
The Create Floor dialog box opens.
Click
to show/hide the parameters.
