DesignSeries00087.pngEditing drains
Mode
Tool
Tool set
Edit
Slab Drainage
Building Shell
Drains can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
Editing drain properties
To edit drain properties:
1.      Select the slab object.
2.      Click the tool and mode.
3.      Right-click on one or more drains and select Edit Drain(s) from the context menu.
The Drain Settings dialog box opens.
4.      Set the properties.
Deleting drains
To delete a drain:
2.      Click the Slab Drainage tool.
3.      Right-click on one or more drains and select Delete from the context menu.
Rotating slope valleys
Editing slab drainage elements
