Command |
Path |
Document Preferences |
File > Document Settings |
The Auto-display detail levels for design layers preference prevents slab components from being drawn at or below a pre-set layer scale factor, creating a cleaner drawing at small scales.
To hide slab components:
1. Select the command.
The Document Preferences dialog box opens.
2. On the Display tab, select Auto-display detail levels for design layers. Enter the scale factors in the scale fields. Slab components display automatically at medium and high detail levels, and do not display at the low setting. See Document preferences: Display tab.
