Spot00013.pngSetting hoist heights
Several commands assist with setting the height of the hoist hooks in relation to loads and associated items or to each other. While these can be set individually from the Object Info palette, using these commands is much easier when editing more than one hoist at once.
Setting the low hook based on the load trim
Setting the low hook based on a selected load
Setting the high hook height
Setting individual high hook height
Selecting hoist objects
