Importing PartSpecCommand |
Workspace: Path |
Import PartSpec |
● Architect: AEC > Machine Design ● Landmark: Landmark > Machine Design ● Spotlight: Spotlight > Machine Design |
The Import PartSpec command imports Thomas Register PartSpec files saved in either DWG/DXF (2D objects) or IGES or ACIS (3D objects) format. It places all parts in a single class on the active design layer and deletes any extraneous layers. The Import PartSpec command does not differentiate between a file created in the Thomas Register and other programs.
To import PartSpec files:
1. Select the command.
The Import Thomas Register PartSpec dialog box opens.
Click
to show/hide the parameters.
2. Depending on the type of file being imported, specify additional import options.
Import |
Description |
2D part from either a DWG or DXF file |
In the Import DXF/DWG Files dialog box, select the file to import. The DXF DWG Import Options dialog box opens. (See DXF/DWG and DWF file import). The only setting that may need to be edited in the DXF DWG Import Options dialog box is Units Setting In File under the Primary Settings tab. This setting refers to the units in the PartSpec DXF or DWG file, not the units of the current Vectorworks file. Do not edit the Import DXF Layers As Classes field under the Graphics Attributes tab or the Group Record Fields under the Objects tab. Changing these options will prevent objects from importing correctly. Depending on the imported part, the Map Colors to Line Weights dialog box and/or the Font Mapping dialog box may open. Make any necessary changes. The part is imported into the file based on the specified settings. |
3D part from an ACIS or IGES file |
If this is an IGES file, the Import IGES File dialog box opens. Select the file to import. If this is an ACIS file, the Import SAT File dialog box opens. Select the file to import. The part is imported into the current class and design layer, and is available for editing and/or converting into a symbol. |
