Command |
Path |
Import STEP (3D only) |
File > Import |
During STEP import:
● Points are imported as a group of 3D loci.
● NURBS curves are imported as a group of NURBS curves.
● NURBS surfaces are imported as a group of NURBS surfaces.
● Closed solids are imported as a group of imported solids.
● Open solids are imported as a group of NURBS surfaces.
● If there is only one element in the STEP .stp file, it is imported as a single element rather than grouped.
Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations.
To import a STEP file:
Select the command then the file to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
