Importing
SketchUpCommand |
Path |
Import SketchUp |
File > Import |
The Import SketchUp command allows architectural drawings created in SketchUp (versions 4 through 2019) to be imported into a Vectorworks file. SketchUp component instances are imported as 3D symbols, and geometry can be designated as walls, roof faces, or floors. After importing, refine the design using Vectorworks editing tools, or replace imported 3D symbols with Vectorworks 3D symbols.
Flexible import options either allow automatic conversion of architectural elements based on their orientation, or allow geometry conversion to be mapped to specific SketchUp materials or layers.
Consider the following points when importing a SketchUp file into a Vectorworks file.
● SketchUp layers are imported as classes in Vectorworks. Geometry from invisible layers in SketchUp have their class attributes set to invisible in Vectorworks.
● SketchUp groups are imported as Vectorworks group objects. If the SketchUp group has a scale assigned, the imported objects inside the group will be converted with that scale.
● SketchUp components are imported as Vectorworks 3D symbols except for the rare cases when they have non-linear scale, in which case they are imported as groups of converted geometry.
● A component which creates an opening in a vertical face is imported as a symbol in wall, if attached to an object imported as a Vectorworks wall.
● When selected, architectural objects in Vectorworks are created from SketchUp faces that are not contained in SketchUp groups of components.
● The SketchUp format supports materials on the front and back of each face of an object. When importing as 3D polygons, only the front material is assigned to the imported objects, as Vectorworks only supports one material for 3D polygons. Both front and back materials are supported when importing as architectural objects.
● When importing as architectural objects, faces which are not part of a group or a component instance in SketchUp will import as roofs, slabs, or floors.
● Walls are unjoined upon import, and may need to be rejoined.
To import a SketchUp file:
1. Select the command.
Alternatively, select the file to import and drag it into an open Vectorworks file.
The Import SketchUp Model dialog box opens.
2. Select the file to import.
The SketchUp Import Settings dialog box opens.
3. Select the method for importing geometry through the options on the Import Method tab.
Click
to show/hide the parameters.
4. Click the Options tab to specify which material properties to import, whether to import geometry as mesh objects or 3D polygons, and set the parameters for architectural objects.
Click
SketchUp geometry and components are imported as specified, and are automatically selected. The Resource Manager displays the converted 3D symbols.
Items are imported at a 1:1 scale. It may be helpful to click Fit to Objects from the View bar to zoom to fit the objects in the drawing. It may also be helpful to adjust the layer scale at this time.
