Command |
Path |
Import mtextur |
File > Import |
An mtextur texture can be imported into Vectorworks as a Renderworks texture and/or an image file. Many of the textures have the reflectivity, transparency, and bump shaders needed for a detailed Renderworks texture. When additional information such as manufacturer name, material, and so on is available in the mtextur resource, this information is included as a searchable tag in the Resource Manager for the imported Renderworks texture and/or image file.
Imported Renderworks textures can be adjusted as needed by Editing textures and shaders.
An internet connection is required to import mtextur textures.
To import an mtextur texture as a Renderworks texture or an image file:
1. Select the command.
An Import mtextur web browser opens.
The Import mtextur Settings dialog box opens.
Click
to show/hide the parameters.
3. Select the settings and click OK.
4. Use the mtextur filters and search function to locate the resources for download.
5. For the selected mtextur resource, click CAD- & BIM-TEXTUR to download.
6. If Automatically close the “Import mtextur” dialog after download is deselected, click Close after you have selected all the resources needed.
The textures/images downloaded are available in the Resource Manager for the current file; the last resource downloaded is active.
