Instruments can be numbered according to the hanging position automatic numbering parameters.
Other numbering options are available from the Spotlight Numbering command; see Numbering light plot objects.
To automatically number the instruments on a hanging position:
1. Select the hanging position.
2. From the Object Info palette, specify the Starting Number, Increment, Numbering Direction, and, for multi-circuit instruments, the Multi-Circuit Numbering.
3. Click Auto Number.
The instruments are automatically numbered. The Unit Number in the Object Info palette of a selected lighting instrument displays its number, which can be changed to override the automatic number.
To display the numbers on the drawing, specify a label legend that includes the Unit Number in the label. See Setting up instrument label legends.
Command |
Path |
Shortcut |
Auto Number Positions |
Spotlight |
● Ctrl+Shift+Alt+O (Windows) ● Cmd+Shift+Option+O (Mac) |
To automatically number all instruments assigned to hanging positions:
Select the command to globally automatically number the lighting instruments in the drawing based on the settings in each hanging position.
If hanging positions are selected when the command is activated, only the instruments on the selected hanging positions are numbered.
