Command |
Path |
Shortcut |
Unrotate 3D Objects |
Modify |
● Ctrl+Shift+0 (zero, Windows) ● Cmd+Shift+0 (zero, Mac) |
The Unrotate 3D Objects command returns any 3D object that has its own coordinate system to its upright position. Use the command to rotate symbols, extrudes, multiple extrudes, and sweeps so that they align with the world coordinate system.
To unrotate a 3D object:
1. Select the 3D object or objects to unrotate.
2. Select the command.
