Command |
Path |
Line Render Options |
View > Rendering |
Use the line render options to control the appearance of lines in Hidden Line, Dashed Hidden Line, and Final Shaded Polygon modes. These settings apply only to the current drawing; they remain in effect in the current drawing until the settings are changed. The current line render settings are saved when you create a template (see Creating templates).
To set line rendering options:
Select the command. The Line Render Options dialog box opens, set the parameters.
Click
to show/hide the parameters.
