Searching for a resource
The Resource Manager has a search box to help you quickly locate a resource using keywords.
To locate and use a resource:
1.      From the Resource Manager tool bar, click the disclosure arrow to the left of the search box and select your search options.
2.      Enter a search string and optionally one or more basic Boolean search operators in the search box and press Enter to execute the search. The search locates the string in resource names, tags, and (if Include Records is selected in the search options) records attached to resources.
Vectorworks recognizes Boolean search operators “” (quotation marks), * (search for strings that begin with the characters indicated), AND, NOT, and OR. Boolean operators can be combined, such as combining two strings inside quotation marks with the word OR, to create precise searches.
The search operators AND, NOT, and OR are case sensitive; they must be entered in all capital letters to function correctly.
The search box retains and displays the last 10 searches; to clear this list, scroll to the bottom of the list and click Clear Recent Searches.
Search example
Possible results
green chair (no quotation marks)
or
green AND chair
Resources with the words green and chair anywhere in the resource name, tags, and optionally record; AND is the default operator
        green chair
        chair with green stripes
        green hatch with chair in the tag
“green chair” (quotation marks)
Resources with the word green immediately followed by the word chair (the exact string inside the quotation marks)
        green chair
green c*
Resources with the word green and any word that begins with the letter c
        green chair
        green couch
        car with green in the tag
“green c”*
Resources with the word green immediately followed by a word that begins with the letter c
        green chair
        green couch
        green car
“green c*”
Resources with the word green immediately followed by the letter c and an asterisk (the exact string inside the quotation marks); an asterisk inside quotation marks is not a search operator
        green c*
cha
or
cha*
Resources with any word that begins with the letters cha; for a single word search, an asterisk operator is automatically added to the end of the search string
        chair
        chain
        chandelier
*cam
or
*cam*
Resources with any word that has the grouped letters cam anywhere; for a single word search, an asterisk operator is automatically added to the end of the search string
        camera
        Varicam
        sycamore
“green chair” AND table
Resources with the word green immediately followed by the word chair (the exact string inside the quotation marks) and the word table
        green chair with table in the tag
        combination symbol named “green chair and side table”
green NOT chair
Resources with the word green but not chair
        green couch
        green car
green OR chair
Resources with the word green or chair
        green chair
        green couch
        red chair
3.      Resources that match the search display in the resource viewer pane. Standard context menu commands are available for the resources, or you can drag the resource to another file if desired. Two additional features are available for search results:
        Hold the cursor over a resource to display a tooltip that shows the resource’s name and location.
        Right-click on a resource, and select Select Resource Location from the context menu to select the file that contains the resource in the file browser pane.
Locating a resource from the drawing
Command
Path
Locate [resource type] in Resource Manager
Context menu
Use the Locate in Resource Manager command to quickly locate resources displayed in the drawing area. This command does not work for record formats or scripts.
To locate a resource from the drawing:
1.      Select the resource (or object containing a resource, such as a rectangle with a hatch) to be located. Select the command.
2.      The Resource Manager automatically navigates to the resource and selects it.
Using resources in your drawing
Resource Manager
