Command |
Path |
Arc into Segments |
Modify > Drafting Aids |
The Arc into Segments command converts a selected arc or circle into an equal number of segments, or divides the arc or circle into segments of a given length. The segments can be drawn as lines or polygons; the original object remains unchanged.
To convert a circle or arc into segments:
1. Select the arc or circle to be converted.
2. Select the command.
The Arc Into Segments dialog box opens.
Click
to show/hide the parameters.
