Creating double lines
Mode
Tool
Tool set
Shortcut
Modes for Creating lines
Double Line
Basic
        Alt+2 (Windows)
        Option+2 (Mac)
The Double Line tool creates a wide variety of constrained and unconstrained double lines. Set the width between the double lines, the offset from the cursor, and whether to create components between the double lines.
To create double lines:
1.      Click the tool and mode.
2.      Click the desired Offset mode to specify the offset method.
Offset mode
Description
Top Control Line
The cursor draws the top/left line
Center Control Line
Creates lines equidistant from the cursor
Bottom Control Line
The cursor draws the bottom/right line
Custom Control Line
Specify an offset value
3.      Enter the distance between the double lines in the Separation field on the Tool bar.
4.      Click Preferences to set other parameters.
5.      Click at the double line’s start point.
6.      Click at the double line’s end point.
Applying components between double lines
To apply a component between the double lines:
In the Double Line Preferences dialog box, click Components. The Wall Components dialog box opens. Specify the component details.
Creating single lines
Creating a break line
Displaying and reversing object direction
Marker attributes
