Mode |
Tool |
Tool set |
Shortcut |
Freehand Edit
Freehand
Basic |
● Alt+5 (Windows) ● Option+5 (Mac) |
A polyline, polygon, rectangle, circle, or arc can be reshaped using the Freehand Edit mode of the Freehand tool. The direction of the curve drawn determines the new object shape. An edited object is converted to a polyline after editing is complete.
To reshape objects using the Freehand tool:
1. Select a valid object.
2. Click the tool and mode.
3. Click to draw the new curve, editing the valid object using the following curve direction guidelines:
Action |
Guidelines |
Change existing curve |
Connect two points with new curve |
Create closure with new curve |
Add a new curve to an existing curve |
Extend existing curve |
Retain partial curve |
4. Click again to finish drawing the freehand polyline edit. The valid object is edited and converted to a polyline.
