Command |
Path |
Shortcut |
Add Solids |
● Model ● Context menu |
● Ctrl+Alt+A (Windows) ● Cmd+Option+A (Mac) |
The Add Solids command joins two or more 3D objects into a single solid object.
To add solids in 3D:
1. Select two or more 3D objects to combine.
2. Select the command.
A single solid object is created from the objects.
