Command |
Path |
Shortcut |
Intersect Solids |
● Model ● Context menu |
● Ctrl+Alt+I (Windows) ● Cmd+Option+I (Mac) |
The Intersect Solids command creates a single solid object from the volume created where two or more 3D objects intersect.
To intersect solids:
1. Select the two or more 3D objects to combine.
2. Select the command.
A single solid object is created from the 3D objects; it is the size and shape of the overlapping volume of the selected objects.
