Direct modeling with the Push/Pull tool
The Push/Pull tool is in the 3D Modeling tool set.
The Push/Pull tool interactively reshapes planar geometry, creating bosses (protrusions) or cutouts on solids by adding or subtracting volume from a solid. The volume is created or subtracted by extruding a face in Extrude Face mode, including all the geometry present on a face in Move Face mode, or extruding a planar NURBS curve (or group of closed, non-intersecting NURBS curves) in Sub-Face mode.
Three modes are available.
Mode
Description
Extrude Face
Selects the planar face of a solid, a 2D planar object, or NURBS curve, to add to or subtract volume, creating perpendicular faces
Move Face
Extends the planar face of a solid, adding or subtracting the face along with any geometry present on the face
Sub-Face
Selects a curve or group of curves to add to or subtract volume from a solid
To preserve the primitive profile geometry of an extrude, right-click on the extrude and select Edit from the context menu. See Object editing mode.
Face-based addition or subtraction
Moving the face of a solid
Curve-based addition or subtraction
Concept: NURBS curves and surfaces
