ArchLand00071.pngSaving the hardscape object settings
Once the hardscape object is set to the desired appearance, you can save the settings for future use or for import into other files.
To save the selected hardscape object settings:
1.      Select a hardscape object.
2.      From the Object Info palette, click Save Hardscape.
The Name Hardscape Symbol dialog box opens.
3.      Enter a unique name.
The hardscape settings are saved as a resource in the “Hardscapes” symbol folder in the active file. Boundary and pathway hardscape objects are assigned unique thumbnail view icons for easy identification. See Resource Manager.
4.      To use a saved hardscape object, do one of the following:
        To draw a hardscape with the Hardscape tool, click Hardscape on the Tool bar. From the Resource Selector, double-click a resource to activate it.
        To apply saved settings to an existing hardscape, from the Resource Manager, right-click on the resource, and select Apply from the context menu. Alternatively, double-click on the resource or drag the resource onto an object to apply it.
Creating hardscapes
Editing hardscape objects
Editing hardscape fills and joint patterns
