Tool |
Workspace: Tool set |
Grade
● Architect and Spotlight: Building Shell ● Landmark: Site Planning |
The grade indicator appearance for all grade objects in the file can be specified globally.
To set global grade object appearance:
1. Click the tool.
2. Click Preferences. Alternatively, select an existing grade object; click Settings from the Object Info palette, double-click the grade object, or right-click on a grade object and select Edit from the context menu.
The Grade Settings dialog box opens. Click the Global Settings tab and enter the desired settings.
Click
to show/hide the parameters.
3. Click Update from the Tool bar to update all grade objects in the drawing with the global settings.
