DesignSeries00017.pngSpace properties
Many, but not all, parameters can be edited from both the Space Settings dialog box and the Object Info palette for ease of access. The space parameters are described in Space settings. Only the parameters that are different on the Object Info palette are described here.
For spaces using plug-in object styles, the parameters that are set by style display for informational purposes but cannot be edited from the Space Settings dialog box or the Object Info palette.
