Tool |
Tool set |
Ramp
Building Shell |
To insert a ramp:
1. Click the tool.
2. From the Tool bar, click either Active Def to select an existing resource from the Resource Selector, or click Preferences and set the default parameters to create a custom object.
3. Click on the drawing to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
4. Optionally, after placement you can create a plug-in object style, which combines style parameters (with a fixed value established by the style) and instance parameters (which can be set independently for each instance of the styled object in the drawing). See Creating plug-in object styles.
