ArchLand00082.pngAuto-classing objects
Certain plug-in objects and symbols have specific default classes, which coordinate with the Layermap worksheet class name standards. The plug-in objects listed here are automatically classed when they are inserted into a file that is set up to use auto-classing (when Enable Auto-classing is selected in the Standard Naming dialog box). If auto-classing is not enabled, these objects are set to a default class when they are inserted into a file.
Object
Default Class
Vectorworks Product
Base Cabinet
Millwork-Main
Architect
Bath-Shower
Plumbing-Fixtures
Architect
Collar
Structural-Framing
Architect
Column
Structural-Columns
Architect, Landmark
Comm Device
DataComm-Devices
Architect
Compartment Sink
Plumbing-Fixtures
Architect
Counter Top
Millwork-Main
Architect
Desk
Furniture-Main
Architect
Door
Door-Main
Architect, Landmark
Drilled Footing
Structural-Footings
Architect
Drip Emitter
Irrigation-SprayPat
Landmark
Elevator
Vert Trans-Main
Architect
Escalator
Vert Trans-Main
Architect
Fireplace
Fixtures-Main
Architect
Grab Bars
Fixtures-Main
Architect
Grade
Site_Util_Storm
Landmark
Guardrail (Curved)
Site-Improvements
Architect, Landmark
Guardrail (Straight)
Site-Improvements
Architect, Landmark
Handrail (Curved)
Fixtures-Main
Architect, Landmark
Handrail (Straight)
Fixtures-Main
Architect, Landmark
Hardscape (tag)
Site-Hardscape Comp-Spec
Architect, Landmark
Hardscape (border)
Site-Hardscape Comp-Border Joint
Architect, Landmark
Hardscape (main area)
Site-Hardscape Comp-Main Joint
Architect, Landmark
Hip and valley rafters
Structural-Framing
Architect
HVAC Damper
HVAC-Duct/Equipment
Architect
HVAC Diffuser
HVAC-Diffusers
Architect
HVAC Elbow Duct
HVAC-Duct/Equipment
Architect
HVAC Flex Duct
HVAC-Duct/Equipment
Architect
HVAC Outlet
HVAC-Duct/Equipment
Architect
HVAC Splitter
HVAC-Duct/Equipment
Architect
HVAC Straight Duct
HVAC-Duct/Equipment
Architect
HVAC Transition
HVAC-Duct/Equipment
Architect
HVAC Vertical Duct
HVAC-Duct/Equipment
Architect
HVAC Vertical Elbow
HVAC-Duct/Equipment
Architect
Irrigation Head
Irrigation-SprayPat
Landmark
Joist
Structural-Framing
Architect
Mullion
Wall-Ext-Glazed
Architect
North Arrow
Notes-Sheet
Architect, Landmark
Parking Spaces
Site-Paving-Marking
Architect, Landmark
Pilaster
Structural-Columns
Architect
Plate
Structural-Framing
Architect
Purlin
Structural-Framing
Architect
Rafter
Structural-Framing
Architect
Ramp
Vert Trans-Main
Architect, Landmark
Receptacle
Electrical-Devices
Architect
Reference Marker
Notes-Sheet
Architect, Landmark
Revision Marker
Notes-Sheet
Architect, Landmark
Ridge
Structural-Framing
Architect
Roadway (Poly)
        Site-Paving-Surface
        Site-Paving-Curb
        Site-Paving-Stations
Architect, Landmark
Roadway (Curved), Roadway (Custom Curb), Roadway (NURBS), Roadway (Straight), Roadway (Tee)
        Site-Paving-Surface
        Site-Paving-Curb
Architect, Landmark
Shelving Unit
Furniture-Main
Architect
Site Modifiers with Grade Limits configuration
Site-DTM-Modifier
Architect, Landmark
Site Modifiers with Pad configuration
Site-DTM-Modifier
Landmark
Site Modifiers with Texture Bed configuration
Site-DTM-Modifier
Landmark
Space (2D) - boundary
Space-Main
Architect, Landmark
Space (2D) - label
Space-Spec
Architect, Landmark
Space (2D) - leader line
Space-Spec
Architect, Landmark
Space (3D) - attributes
Space-Patterns
Architect, Landmark
Stair
Vert Trans-Main
Architect, Landmark
Switch
Electrical-Devices
Architect
Table and Chairs
Furniture-Main
Architect, Landmark
Toilet Stall
Fixtures-Main
Architect
Header
Structural-Framing
Architect
Utility Cabinet
Millwork-Main
Architect
VBvisual Plant
Landscape-Plants
Architect, Landmark
Wall Cabinet
Millwork-Main
Architect
Window
Window-Main
Architect, Landmark
Workstation Counter
Furniture-Main
Architect
Workstation Overhead
Furniture-Main
Architect
Workstation Panel
Furniture-Main
Architect
Workstation Pedestal
Furniture-Main
Architect
