Creating saved views
Command
Path
Save View
View
To save the current drawing area view:
1.      Select the command.
Alternatively, from the Organization dialog box, click the Saved Views tab, and then click the New button. If Vectorworks Design Series is installed, from the Navigation palette, click the Saved Views tab, and then select the New command from the navigation menu.
The Save View dialog box opens.
2.      Specify the view options, the active layer and class, and the visibilities of layers and classes.
The saved view is available from the Saved Views menu and from the Organization dialog box.
Editing saved views
Creating or editing saved views using the saved views menu
Setting global visibility with class and design layer options
Visibility columns
