DesignSeries00078.pngX wall joins
Mode
Tool
Workspace: Tool set
Shortcut
X Join
Wall Join
        Architect and Spotlight: Building Shell
        Landmark: Building Shell and Site Planning
        Alt+J (Windows)
        Option+J (Mac)
X Join mode joins two wall segments at the point where they intersect. Because neither wall segment’s length is altered, the two segments must already intersect in order to use this mode.
To join walls with the X Join mode:
1.      Click the tool and mode.
Alternatively, right-click on the first wall to join and select Join from the context menu.
2.      Select the wall segment to become non-load bearing.
3.      Select the wall segment to become load bearing.
The first wall segment selected is split into two wall segments, which are joined to the load bearing wall.
Joining walls
Joining walls with the Fillet tool
