ArchLand00044.pngElevation Benchmark
The Elevation Benchmark tool represents different levels in elevation drawings; two different elevation benchmark styles are available: ISO and US.
To place an elevation benchmark object:
1. Click the Elevation Benchmark tool from the Dims/Notes tool set.
2. Click on the drawing at the desired location to place an elevation benchmark linear object.
3. Click to set the length and rotation of the elevation benchmark.
If this is the first time the object is inserted in this session, the Object Properties dialog box opens. These parameters apply to subsequent placements of the object and can be changed in the Object Info palette. Click OK.
After creation, multiple elevation benchmark objects can be aligned and distributed with the Align/Distribute Leader Lines command; see Aligning and Distributing Leader Lines.
Using Notation Objects
www.vectorworks.net
