DesignSeries00168.pngFlange Welding Symbol
To insert a flange welding symbol:
1. Click the Welding Sym-Flange tool from the Dims/Notes tool set.
2. Click to place the object in the drawing, and click again to set the object’s rotation. If this is the first time the object is placed in the drawing, an object properties dialog box opens. These parameters apply to subsequently created objects; they can be changed later by accessing them from the Object Info palette.
3. Specify the object properties and click OK.
4. Once the object has been placed, its marker can be selected from the Attributes palette (see Marker Attributes).
Welding and Surface Texture Symbols
Editing the Arrow Segment
Marker Attributes
www.vectorworks.net
