Single
Object ConnectionTo connect a database to an object:
Select an object.
On the Data tab of the Object Info palette, click the box for the selected format to attach the record format to the object instance. (See Attaching Record Formats to Symbols and Objects.)
The Record Fields display with default values from the record format.
Select Tools > Database > Object Connection. Alternatively, click Object Database Connection from the Data tab of the Object Info palette.
The Object Database Connection dialog box opens. If a row was previously selected for the object, it appears highlighted and bolded.
Click Use Selected Database Table Row, and then select the appropriate row for the selected object.
Click OK.
The record fields are populated from the database table for the record instance attached to the object.
