Tapped HolesBoth 2D and 3D tapped holes are available. The 3D tapped hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract Solids).
To insert a tapped hole:
Click the desired Hole - Tapped inch or metric tool from the Detailing tool set.
Click to place the object in the drawing, and click again to set the rotation.
