Linear Roller
ChainsThe 2D linear roller chain is a linear object, while the 3D linear roller chain is a point object.
To insert a linear roller chain:
Click the Roller Chain - Linear tool from the Machine Components tool set.
Click to place the object in the drawing, and click again to set the rotation.
