To insert a door in Vectorworks Design Series:
Select the Door tool from the Building Shell tool set.
Alternatively, if placing a curtain wall door into a curtain wall, select a panel with the Edit Curtain Wall tool, and then right-click (Windows) or Ctrl-click (Mac) on the panel and select Insert Door from the context menu. The door is automatically inserted as a curtain wall door.
If this is the first time a door is inserted into the drawing, or if you wish to change the default preferences that apply to subsequently placed doors, click Preferences from the Tool bar.
The Door Settings dialog box opens. The settings are grouped into several panes of related parameters, which are listed on the left side of the dialog box. Select each pane and specify the door parameters. Click OK to set the door parameters and close the dialog box. These parameters can be edited for placed doors from the Object Info palette, as described in Door Properties.
Click in the drawing area or in a wall to set the insertion point of the door, and click again to set the rotation. The direction of a door inserted in a wall can be changed later by clicking Flip from the Object Info palette or from the context menu.
Several features of the door are described as “interior” or “exterior.” These include trim and wall-wrap parts. These elements are determined based on the internal and external faces of the wall. The left side of the wall (as viewed along the wall direction) is always “exterior,” and the right side is “interior” (see Wall Direction). Flipping the door does not flip these elements.
3D Visualization options are not enabled for the Opening Configuration.
Jamb options are not enabled for the Opening Configuration or for curtain wall doors.
Leaf options are not enabled for the Opening Configuration.
Lights options are not enabled for the Opening Configuration or for curtain wall doors.
Threshold options are not enabled for the Opening Configuration.
Transom options are not enabled for the Opening Configuration or for curtain wall doors.
Trim options are not enabled for the Opening Configuration or for curtain wall doors.
Lintel options are not enabled for the Opening Configuration or for curtain wall doors.
Hardware options are not enabled for the Opening Configuration.
Kick Plates options are not enabled for the Opening Configuration or for curtain wall doors.
Centerline markers options are not enabled for curtain wall doors.
Interior wall detail options are not enabled for curtain wall doors.
Exterior wall detail options are not enabled for curtain wall doors.
The visibility of the overall 3D door is controlled by the Class setting from the Object Info palette; part settings are controlled from the Door Settings dialog box.
Doors play a critical role in energy analysis calculations. Energy is lost through any door glass, and when the door is opened, but energy is also gained by solar radiation through the door glass. Accurately determining the R-Value/U-Value and the shading factor is essential for the overall energy analysis.
Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes.
Certain data fields represent calculated values and cannot be edited; as a result, the Field Name and Field Value appear dimmed for those data fields.
