When a slab style is deleted, all instances of the style in the current document can be deleted completely or replaced with another existing slab style. Multiple slab styles can be selected and deleted or replaced at the same time.
To delete a slab style:
In the Resource Browser, select the slab style to delete, and select Delete from the Resources menu.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on a slab style, and select Delete from the context menu, or select the slab style and press the Delete key.
If there are any instances of the slab style currently in the drawing, the Delete Slab Style dialog box opens. Otherwise an alert displays to confirm the deletion.
Click Yes.
If Delete Slab Style Completely is selected, the slab style and all instances of the style are deleted. If Delete and replace Slab Style with is selected, the Slab Replacement dialog box opens automatically.
If slabs with different slab styles were selected for replacement, the current slab preview is blank and components do not display.
Click OK to replace the slab style of the selected slab.
If you click Cancel, the previous slab style deletion is also canceled.
