Furniture and Fixtures
DesignSeries.pngInserting Cabinets
All Vectorworks products include three types of cabinets for inserting in a drawing file—base, wall, and utility cabinets. In the Vectorworks Fundamentals product, the cabinet objects are inserted from an object library through the Resource Browser. In the Vectorworks Design Series products, the cabinet objects are inserted with the various cabinet tools. Cabinet door and drawer handles are provided in libraries; a selected handle is automatically imported into the current file and displays in the Resource Browser; see Resource Libraries.
To insert a base cabinet:
To insert a utility cabinet:
To insert a wall cabinet:
  1. Select the Base Cabinet, Utility Cabinet, or Wall Cabinet tool from the Furn/Fixtures tool set.
  2. Click on the drawing or wall to place the cabinet, and click again to set the rotation.
Base Cabinet Parameters
Utility Cabinet Parameters
Wall Cabinet Parameters
vectorworks.net
