Exporting in COLLADA Format (3D only)This command exports 3D objects in the unified view or active layer to .dae format. The .dae file and any texture image files associated with it are placed in a folder named after the .dae file. This format may provide better results than the older 3DS file format.
To export a COLLADA file:
Select File > Export > Export COLLADA (3D only).
Specify the export file name and destination, and then click Save.
