During IGES import:
● Points are imported as a group of 3D loci.
● NURBS curves are imported as a group of NURBS curves.
● NURBS surfaces are imported as a group of NURBS surfaces.
● Closed solids are imported as a group of imported solids.
● Open solids are imported as a group of NURBS surfaces.
● If there is only one element in the IGES file, it is imported as a single element rather than grouped.
Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations.
To import an IGES file:
Select File > Import > Import IGES.
The Import IGES File dialog box opens.
Select the file to import, and click Open.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Export IGES (3D only) command exports 3D curves, surfaces, and solids from a Vectorworks file into IGES format (version 5.3). Closed solids are exported as solids, while open solids are exported as a collection of surfaces.
Objects that are exported to an .igs file include:
● 3D loci |
● 3D polygons |
● Architectural objects (wall/slab/column/stair) |
● Chamfers |
● NURBS curves and surfaces |
● CSG solids (add/subtract/intersect/section) |
● Fillets |
● Groups |
● Extrudes and multiple extrudes |
● Parametric objects |
● Shells |
● Solids (sphere/cone/hemisphere) |
● Sweeps |
● 3D Symbols |
To export an IGES file:
Select File > Export > Export IGES (3D only).
The Export Options dialog box opens.
Select Export Solid as Trimmed Surfaces to export a solid as several different “bodies” (for example, a cube exports as six bodies); otherwise, a solid is exported as a single body.
Click OK.
Specify the export file name and destination, and then click Save.
Export Item |
Export Result |
NURBS curve |
IGES Entity Type 126 |
NURBS surface |
IGES Entity Type 128 |
Trimmed NURBS surface |
IGES Entity Type 144 |
Closed solid |
IGES Entity Type 186 |
