The Vectorworks program imports Stereolithography (STL) files, which are widely used for 3D printing, prototyping, and manufacturing. Polygon mesh objects import into a Vectorworks file as mesh objects.
To import an STL file:
Select File > Import > Import STL (3D only).
The Import STL File dialog box opens.
Select the file to import, and click Open.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Export STL (3D Only) command exports 3D surfaces and solids to an STL (Stereolithography) file. Once exported, this file can be used for rapid prototyping purposes or imported into other CAD packages.
To export an STL file:
If 3D objects from only one layer should be exported, make that layer active. If only selected objects should be exported, select the objects.
Select File > Export > Export STL (3D only).
The Export STL Options dialog box opens.
Select the export options, and then click OK.
Specify the export file name and destination, and then click Save.
Click here for a video tip about this topic (Internet access required).
