Spot00070.pngFind and Modify
Custom selection criteria can be defined to quickly and easily search for instruments, lighting positions, and accessories and to perform an action upon the search results.
To find and modify objects:
  1. Select Spotlight > Find and Modify.
  2. The Find and Modify dialog box opens.
  3. Select the type of object to be searched and specify the change(s) to occur to the items found.
  4. Once the find and modify criteria have been defined and action(s) specified, click OK. The selected change(s) will occur to the items located by the search.
Inserting Lighting Positions
Adding Lighting Instruments
Adding Accessories
vectorworks.net
