Spot00010.pngPlacing Lighting Pipe Ladders
The Lighting Pipe Ladder is a is a three-click rectangular object, and can be inserted in Center-line Placement mode or Edge Placement mode.
Placement Mode
Description
Center-line
Click once, and then again, to define the length through the center of the ladder. Click again to specify the ladder width
Edge
Click once, and then again, to define the length along the edge of the ladder. Click again to specify the ladder width.
To insert a lighting pipe ladder:
  1. Click the Lighting Pipe Ladder tool from the Spotlight tool set, and then click a placement mode from the Tool bar.
  2. Click in the drawing area to insert the ladder.
To use the lighting pipe ladder as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
Inserting Lighting Positions
Creating Lighting Positions
vectorworks.net
