Spot00006.pngPlacing Lighting Pipe Objects
Insert and configure a lighting pipe object with the Lighting Pipe tool.
To insert a lighting pipe object:
  1. Click the Lighting Pipe tool from the Spotlight tool set.
  2. Alternatively, create a polyline and then select the Create Objects from Shapes command (see Creating Objects from Shapes).
  3. Click in the drawing area to begin drawing the lighting pipe.
  4. To draw a multi-segment pipe, click to set the end of one segment and start the next.
  5. Create a curved pipe by changing the vertex type (see Creating Polylines).
  6. Double-click to complete the lighting pipe polyline.
To use the lighting pipe as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
Inserting Lighting Positions
Creating Lighting Positions
vectorworks.net
