Spot00008.pngInserting a Photometric Grid
The photometric grid is a is a three-click rectangular object, and can be inserted in Center-line Placement mode or Edge Placement mode. The grid can be tilted, accounting for sloped or raked stages.
Placement Mode
Description
Center-line
Click once, and then again, to define the length through the center of the grid. Click again to specify the grid width.
Edge
Click once, and then again, to define the length along the edge of the grid. Click again to specify the grid width.
To insert a photometric grid:
  1. Ensure that each lighting instrument contributing to the illumination is focused.
    The light beams do not have to be drawn for calculations to be made.
  3. Click the Photometric Grid tool from the Spotlight tool set, and then click a placement mode from the Tool bar.
  4. Click in the drawing area to insert the photometric grid.
After placing the photometric grid, set the grid’s Z value from the Object Info palette; illumination values vary depending on the grid’s elevation.
Obtaining Photometric Data
Inserting a Photometer
Using Photometric Threshold Settings
Assigning a Focus Point to a Lighting Instrument
vectorworks.net
