Spot00017.pngReviewing Generated Paperwork
Once the paperwork has been formatted and generated, it can be checked and printed.
Generated Magic Sheets
If Magic Sheets were generated, a new design layer is added to the file. Depending on the type of Magic Sheet generated, the new design layer is called Magic Sheet-Area or Magic Sheet-Color. The magic sheets are placed on this design layer, and formatted to the specified page size (select View > Zoom > Fit to Objects if the Magic Sheet items cannot be seen). If the light plot parameters are changed, the magic sheets must be regenerated to reflect the updates.
Paperwork Worksheets
The specified reports and schedules, once generated, display in the Resource Browser under the Worksheets heading of the current file.
For more information on worksheets, see Worksheets.
The following points should be remembered when working with generated paperwork:
●    Edits to this type of worksheet do not update the light plot parameters.
●    If the light plot parameters are edited, this type of report or schedule must be regenerated to reflect the updates.
vectorworks.net
