Editing a Callout Object
Editing the Callout Text
To edit the text of an existing callout object:
  1. Either double-click the callout object with the Selection tool, or select the callout object and click Edit Note from the Object Info palette.
  2. The Notes Manager: Callout dialog box opens.
  3. Enter the text changes and click OK.
Editing the Callout Graphic
●    Edit the callout parameters from the Object Info palette; see Inserting Callouts or Keynotes.
●    Use the Attributes palette to change the marker type.
●    Set the text attributes using the Text > Format Text command. Alternatively, assign a text style to the callout.
●    On the drawing, a callout object contains control points that can be moved with the mouse to change the callout text width, shoulder length, and endpoint position. A curved callout leader includes additional control points for adjusting the leader curvature.
●    If there are several callout objects, use the Align/Distribute Leader Lines command to improve readability (see Aligning and Distributing Leader Lines).
●    Callout objects are specified and drawn in page scale; they draw to the same apparent size, regardless of the layer scale. The callout object automatically re-scales if the layer the callout is on is re-scaled, or if the callout is cut and pasted between layers of different scales.
The Attributes Palette
Formatting Text
Using Text Styles
Specifying Callout or Keynote Legend Bubble Shadow Settings
vectorworks.net
