The Convert to Polygons command changes any object with a surface into the 2D polygon or series of polygons needed to create it.
Circles and ovals can also be converted. However, especially when converting circles, the accuracy of the polygons depends on the 2D conversion resolution setting chosen in the Vectorworks Preferences dialog box.
When most closed 3D geometry is converted to 2D polygons with the hidden line rendering option, back-facing polygons are discarded.
To convert an object to polygons:
Select the object to convert.
Select Modify > Convert > Convert to Polygons.
If the object can be rendered, select either the wireframe or hidden line rendering conversion option.
Click OK.
The object is converted to a group of polygons. To select an individual polygon, first select Modify > Ungroup.
