The Ungroup command ungroups objects or groups that were previously combined with the Group command. Nested groups must be ungrouped one at a time.
To ungroup a group of objects:
Select the group to ungroup.
Select Modify > Ungroup.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the group, and select Ungroup from the object context menu.
A plug-in object will lose its plug-in functionality if it is ungrouped. Confirm that the high-level objects should be ungrouped.
Also, if the group has attached records, you are prompted to attach the records to the ungrouped objects. Click Yes to transfer the records to each ungrouped item; click No to discard the record information.
If you transfer records to multiple ungrouped objects, you will have duplicates. This may be a problem if the original grouped object was being tracked on a worksheet, for example.
