Splitting Objects and NURBS Surfaces with the Split Tool
The Split tool is in the Basic palette.
The Split tool splits the following objects.
Vectorworks Fundamentals Objects
    3D solid objects (extrudes, cones, cylinders, spheres, hemispheres)
    2D objects (ovals, circles, rectangles, rounded rectangles, arcs, lines, polylines, polygons)
    Revision clouds
    Pillars
    NURBS curves
    Walls
    NURBS surfaces
    Floors
    Viewports
    Roof faces
    Subdivisions
Vectorworks Design Series Objects
    Property lines
    Redlines
    Massing models
    Stipples
    Site modifiers
    Spaces
    Seating layouts
    Hardscapes
Splitting an object may change its type; for example, splitting a roof face creates a solid section, which can no longer be edited as a roof face.
The following modes are available for the Split tool.
Mode
Description
Point Split
Cuts an object or NURBS surface at a specified point
Line Split
Splits an object or NURBS surface along a cutting line
Line Trim
Splits an object or NURBS surface along a cutting line, and then keeps a designated side
All Objects
For Line Split and Line Trim modes, splits all objects along a cutting line regardless of the current selection
Currently Selected Objects
For Line Split and Line Trim modes, splits only the currently selected objects along a cutting line
Surfaces generated by successive splitting can be joined together with the Compose command (see Composing and Decomposing Objects and Surfaces).
This tool may not be able to manipulate certain types of surface geometry (see Surface Geometry Requirements).
Point Split Mode
Line Split Mode
Line Trim Mode
Splitting or Trimming Solids
vectorworks.net
