When a roof style is deleted, all instances of the style in the current document can be deleted completely or replaced with another existing roof style. Multiple roof styles can be selected and deleted or replaced at the same time.
To delete a roof style:
In the Resource Browser, select the roof style to delete, and select Delete from the Resources menu.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on a roof style, and select Delete from the context menu, or select the roof style and press the Delete key.
If there are any instances of the roof style currently in the drawing, the Delete Roof Style dialog box opens. Otherwise an alert displays to confirm the deletion.
Click Yes.
If Delete Roof Style Completely is selected, the roof style and all instances of the style are deleted. If Delete and replace Roof Style with is selected, the Roof Replacement dialog box opens automatically.
If roofs with different roof styles were selected for replacement, the current roof preview is blank and components do not display.
Click OK to replace the roof style of the selected roof.
If you click Cancel, the previous roof style deletion is also canceled.
